My New BRE ProRam
Old Oct 9, 2004 | 12:59 PM
  #106
ShawnMacAnanny's Avatar
Re: My New BRE ProRam
Originally Posted by kmook
Well the intake is all ready to go on now that the fuel connections to the stock lines have been figured out and done. I had a lot of crap go wrong on the car (clutch, trans, brakes, hurricane damage, my new hood got damaged by fedex, etc) so i had a lot of other things put the intake and other upgrades on the back burner. But i'm still trying to push forward
JEEZ. i just read this ENTIRE thread only to find out you've been lazy?! Haha I'm just messin. Awsome intake by the way. That throttle body is so cool. Is it completely cut out behind the butterfly, or are there just two larger holes?
Old Oct 9, 2004 | 01:02 PM
  #107
kmook's Avatar
Advanced Tech Moderator
Yep it is completely cut out behind the butterfly
Old Oct 9, 2004 | 02:19 PM
  #108
arnie's Avatar
Originally Posted by z28draco
I make the "half sheet metal intakes" from ltx castings for turbo and supercharged guys (being a supercharged guy myself)....them engines love big plenum short runners...
Big plenums with short runners.... I take it you've tried the noticeably longer runner in combination with the larger plenums without success? Or, are you able to merely state that they like the larger plenums?
Old Oct 11, 2004 | 06:22 AM
  #109
z28draco's Avatar
i have tried both and what i found was that longer runners with large plenums work great for n/a applications, but each one has to be tuned specifically for the engine it is being built for..... and under boost the difference between the 2 runner lengths is almost un-noticable, some larger runners can actually be restrictive on boosted applications...plenums can also be restrictive like in the ltx intake castings, i got a 24rwhp at 11psi increase in modifing the upper plenum and smoothing out the runners alone...thats why i said the lt1/4's under boost love the larger plenum with the shorter runners...
Old Oct 11, 2004 | 05:52 PM
  #110
arnie's Avatar
Thank's for the followup post. I believe I'll go ahead with the longer runnered intake. As long as it doesn't adversely affect [under boost] operation, I figure it couldn't hurt, while engine is running, prior to turbos being spooled.
Old Oct 11, 2004 | 06:27 PM
  #111
bdc95ta's Avatar
how would you go about calculating proper intake runner lenght for a particular application (blown & na), mathematics wise.
-b
Old Oct 11, 2004 | 08:13 PM
  #112
SStrokerAce's Avatar
-b
Scientific Design of Exhaust & Intake Systems
That would be the best place to start. It was first published in 1962 but all the same things apply.
Bret
Old Oct 30, 2004 | 10:13 PM
  #113
lt4 fd's Avatar
... did a search and didnt find any new postings about results just like to hear an update
Old Oct 31, 2004 | 12:07 AM
  #114
kmook's Avatar
Well i don't mind putting it (and the whole new top end that's going on along with the intake) on a stock bottom end really, if it had lower milage or i had a beater. But mine has 116k miles and i don't have a beater right now... so i ordered a 355 from AP a few weeks ago, so i'm just waiting on that.
Old Nov 5, 2004 | 10:38 PM
  #115
Dave69Z's Avatar
Are you using the stock plastic lines to feed the motor? How did you adapt them to AN fittings? Or are you using a stock style regulator with the snap on connectors and using the adapter you can get from Pure Performance?
Dave
Old Nov 5, 2004 | 10:45 PM
  #116
kmook's Avatar
Dave
Yes stock plastic lines, into these-
http://www.technologyorgasm.com/upload/fittings.JPG
from Jim Miller at TubeTech, 479-394-6466 It's the only place i could ever find that makes something like those.
Old Nov 6, 2004 | 09:12 AM
  #117
Dave69Z's Avatar
Thumbs up Re: My New BRE ProRam
Thanks, just what I was looking for.
Old Dec 27, 2004 | 05:21 PM
  #118
NJLT1SS's Avatar
So have there been any results posted yet with this intake? Im curious to see what kind of power it makes on a 355. Did Bret also do the heads, or just a cam to work more with this intake rather than a ported factory casting.
Nick
Old Dec 27, 2004 | 06:53 PM
  #119
kmook's Avatar
Nick
No results yet. I'm not sure what your question is at the end... but no Bret didn't do the heads, Blackstone did. And yes Bret designed my entire valvetrain.
Old Dec 28, 2004 | 12:43 PM
  #120
NJLT1SS's Avatar
Hey Kmook, I guess my question in general is what kind of results did you get. I will be very interested to know once you get the setup running and tuned. Sounds like a killer combination, with the heads done by Blackstone, and the valvetrain set up by Bret, this set up should make some of the bigger cube motors raise an eyebrow or two Looks like from the pics Bret used a tunnel ram base and modified it from there. With the intake powderedcoated black its kinda hard to see any details, or at least ones that would give away more about its construction.
Nick
