main tolerances, am I reading this right?
Old Mar 18, 2004 | 01:13 PM
v7guy's Avatar
in reading the tolerances for the mains the service manual say the tolerances for the first main are 62.189mm-62.212mm
I'm assuming that the clearance is those two numbers subtracted
for example
62.212-62.189=.023mm
so I would not want to see a measurement with plastigauge that would read more than .023 correct?
Old Mar 18, 2004 | 02:10 PM
rskrause's Avatar
Moderator
Most people run .0025" on an iron block. On the rear, run 0.0030" inch with iron. Your numbers look like tolerances for the main bearing diameter. The clearance is the (bearing diameter - crank journal diameter). The bearing diameter is measured with the main caps installed and torqued to spec.
Rich Krause
Old Mar 18, 2004 | 02:35 PM
v7guy's Avatar
ah yes, I was looking at the wrong part, thanks for pointing it out
NewsBot
Apr 30, 2015 09:50 AM
R@mpage
Apr 20, 2015 10:02 AM
ad356
Apr 11, 2015 08:49 AM
carl.froehlich
Mar 13, 2015 12:38 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
