Intake manifold repair difficulty?
Old Mar 18, 2004 | 01:55 PM
sabre81's Avatar
I want to tackle the job, but im just wondering the difficulty of it. It seems pretty easy to me however ive never done this type of job before. Most i have done is install my exhaust and replace the Throttle body. Should i go for it?
Old Mar 18, 2004 | 02:08 PM
SweetZRag's Avatar
What kind of repair? Do you mean remove and replace?
Old Mar 18, 2004 | 02:25 PM
Bastardcat's Avatar
I didn't think it was that difficult. I printed out instructions for the repair I found at www.ProjectTransAM.com and didn't have any problems. That was the first time I had ever done anything like that as well. So I'd say if you take your time and know what you're up against ahead of time it shouldn't be a problem.
Old Mar 18, 2004 | 02:34 PM
2MCHPSI's Avatar
While most intake help guides I have seen here are good and informative, make sure to do not take certain advice.
Do not use sandpaper when cleaning gasket areas. Some guides say to actually do that.. Ridiculous..
You do not need to let the car sit for 24 hours for the sealant to cure, let alone even 2 hours. Put the car back together and drive it.
Use very good quality sealant and this is the most important aspect when doing an intake leak. I prefer GM Grey sealant which you can pick up at any dealer.
Old Mar 18, 2004 | 02:45 PM
ibanez6rg's Avatar
I would definitely let it sit over night before driving the car. After a few hours its not even hard. Re-torque the bolts after awhile, too. Jared also gave me a few tips to "score" the block and intake where you're laying down the RTV. Also carry the RTV up on to the intake gaskets. Make it a big bead, nothing small. Also, use something on the bolts (RTV, sealent).
Old Mar 18, 2004 | 03:06 PM
Brent94Z's Avatar
Super Moderator
There are more pics here for ya...
http://www.bfranker.badz28.com/fbody/intakefix.htm
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Elcojoe
Nov 17, 2014 10:27 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
