MAF readings
Old Feb 26, 2004 | 12:20 PM
BigBobsCamaro's Avatar
MAF readings
Does anyone know for sure what the maf readings should be on a stock (k&n filter, flowmaster muffler) 95 z28 lt1? I'm going to replace the connector and after I do I'm going to have the maf checked. What should the readings be from idle on up? Thanks
Old Feb 26, 2004 | 12:34 PM
slverbullet's Avatar
sorry to jump on this post, but i'm interested in this as well.
ps- i do have a CAI if that matters.
Old Feb 26, 2004 | 02:17 PM
You will see 6 to 9gps at idle, and well over 200gps at WOT/max rpm. 240gps for a relatively stock setup.
Have you read my online scanner writeup?
The WOT numbers are at sea level. The higher you go in elevation, the lower the mass air flow will be at WOT/max rpm.
DirtyDaveW
Dec 1, 2016 05:37 PM
R@mpage
Apr 20, 2015 10:02 AM
lt1matt
Mar 21, 2015 07:35 PM
pete53
Dec 9, 2014 07:31 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
