MAF question
Old Oct 7, 2003 | 06:14 PM
ead94z28's Avatar
Question MAF question
If the MAF sensor is not reading right will that affect the idle at all?
Old Oct 7, 2003 | 06:50 PM
Buttercup's Avatar
Sure can, especially at lower frequencies (airflow) such as that at idle. It has especially been a problem with CAI's. The oil used on the filter tends to coat the MAF wires, desensitizing them. It's not a bad idea to remove the MAF and carefully clean the elements on it with non-residue electronics cleaner.... be careful with 'em though
Of course there are many other things that can affect idle
Old Oct 7, 2003 | 07:06 PM
ead94z28's Avatar
Thanks. I am getting a code for it. I did clean it but it did not help. I am still getting a choppy idle and I believe thats the culprit.
Old Oct 7, 2003 | 09:11 PM
Buttercup's Avatar
As with all suspected bad sensors, make sure to inspect the wiring thoroughly. If you've got another f-body/'Vette enthusiast around try swapping MAF's. If it gets real bad you can simply unplug the MAF and the car will default to speed density mode.
Old Oct 7, 2003 | 09:49 PM
ead94z28's Avatar
I unplugged it and the coolant fans went on when I started the car and it idled pretty rough.
lt1matt
Mar 21, 2015 07:35 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
RedLineRev
Jan 23, 2003 03:51 PM
