LTCC is driving me nuts
Old Jul 15, 2004 | 07:57 PM
  #46
Mystic95Z's Avatar
I have a Meziere pump and it doesn't seem to affect my LTCC at all. I can tell you though my MPG has picked up since I put it on last Sun. I am at 220 miles right now and its probably got another 20+ miles left. I'd normally be refilling by 200 or before.
-Tony
Old Jul 15, 2004 | 08:10 PM
  #47
bunker's Avatar
Hmm.. I did upgrade to the Impala alternator, the stock ones are 105 AMP & the one I got is a 140AMP. It might be location related if you have an electric water pump like I have, so it wouldn't hurt to try relocating the box as mentioned & see what happens.
Matt.
Old Jul 15, 2004 | 09:06 PM
  #48
93Z4ME's Avatar
I didn't know the stock alternator in 93 was only 105 amp, is the 140 amp Impala alt of a 93 also? Are the 94-97 alternators incompatible with 93's?
Old Jul 15, 2004 | 09:47 PM
  #49
bunker's Avatar
93+ alternators in F-body cars except the B4C police F-bodies are all 105 AMP, the only difference between the 93 alternators & the 94+ is the fan in the front is plastic on the 94+ instead of the jaged steel one the 93 has, but they are all interchangeble.
The 94+ Caprice/Impala alternators 140 version are a bit different in that you have to loosen the bolts that hold the 2 halves together & turn the back so it looks like your 93+ alternator in the bac, its just the rear casing is fliped on those. Only thing is you will only be able to mount the B-body (impala) alternator on 2 bolts on the f-body unless you use a stock manifold bracket that bolts to the exhaust manifold & then to the alternator, you can still use that to have 3 bolts hold it.
Mine is just held on by 2 bolts & I rev my engine to 7k RPM no problems.
Also the Impala/caprice alternators have a smaller pulley on there which will eliminate the need to buy the alternator pulley if you buy an underdrive pulley for the crank, because essentially if you buy the underdrive pulley kit that comes with the alternator pulley its the same diameter as the B-body pulley.
Hope this helps.
Matt.
Old Jul 16, 2004 | 11:51 AM
  #50
Tekprodave's Avatar
The voltage may not drop with RPM if it is low all the time. What voltage are you seeing with the car on. Mine is well over 14 volts. If you don't have a volt meter the needle should be past the battery icon on the gauge. The issue may not be related but it doesn't hurt to have good voltage. With Gary's cables the car starts easier for better gas mileage, better spark energy, the stereo sounds better, lights are brighter, etc.,etc., etc. One of the best $50 mods I've ever done.
Originally posted by 93Z4ME
I didn't consider the alternator being a problem because the voltages don't drop with RPM, but I guess that doesn't mean the current is adaquate. Mine is a 93 so only has the 120 amp alternator. I also have ASP underdrive pullies but have never had a problem with charging even with 400 watt stero cranking, AC on, a CSI waterpump and cooling fans at a stop sign at idle at night.... (did I forget anything?)
Old Jul 17, 2004 | 12:12 AM
  #51
93Z4ME's Avatar
At idle (900 RPM) with everything on I only read about 11.5 but at anything above 1000 RPM I get about 13-13.5, if I don't have everything on it reads ~14. Where do you get "Gary's Cables" from?
Old Jul 19, 2004 | 12:19 PM
  #52
Tekprodave's Avatar
Re: LTCC is driving me nuts
You can contact Gary directly. Just click the link:
www.geocities.com/sscruising@sbcglobal.net
Old Jul 19, 2004 | 08:21 PM
  #53
bdc95ta's Avatar
I tried emailing Gary twice with no luck! It returned my email and said the addy didn't exist. Does he have a phone # perhaps?
-b
Old Jul 20, 2004 | 10:59 AM
  #54
Tekprodave's Avatar
Try this email addy:
garyclark0907@sbcglobal.net
I told him you were trying to contact him and got a response so give it a try.
DirtyDaveW
Mar 15, 2015 07:01 PM
mikey4play
Mar 15, 2015 11:45 AM
Fatdog2
Feb 13, 2015 08:19 PM
maybe2fast
Feb 5, 2015 05:14 AM
squarehead
Nov 21, 2014 08:02 PM
