Lt1 to LS1 Driveshaft
Old May 1, 2020 | 04:28 PM
WhiteWS6's Avatar
Replacing the seal on the back of my T56 since it was leaking, have a friends old Aluminum driveshaft laying around and thought I might toss it in. My steel one has a decent ding that I believe has been causing some slight vibration. Is it just me or does it appear the yolks is slightly longer on the steel driveshaft compared to the Aluminum one? Or is this caused due to a separate transmission from one or the other? Any info would be great.
Thanks, Grant
Old May 1, 2020 | 06:37 PM
WhiteWS6's Avatar
Re: Lt1 to LS1 Driveshaft
Actually after lining them up a bit better there's almost no difference, but I can see on the steel one where it actually extends past the 'threads' that go on the output output shaft. Where on the Aluminum one, the 'threads' actually start immediately.
Old May 1, 2020 | 08:59 PM
WhiteWS6's Avatar
Pic of the diff. I'm talking about
Old May 1, 2020 | 09:56 PM
The snout lengths are slightly different, but overall length should be the same. They are interchangeable without issue.
Old May 1, 2020 | 10:00 PM
WhiteWS6's Avatar
Ok Awesome, just the info I needed. Thanks!
Old May 1, 2020 | 10:52 PM
And those are “splines”
Old May 1, 2020 | 11:01 PM
WhiteWS6's Avatar
Thank you for the calarification!
Thanks, Grant
Old May 2, 2020 | 07:59 AM
Germansheperd's Avatar
Works great. I picked up a used one and added two new u-joints. Good cheap mod for a stock LT1.
Old May 2, 2020 | 01:47 PM
WhiteWS6's Avatar
Was able to successfully get the driveshaft in nice and smooth. Had to drop the torque arm out of the way probably due to my custom exhaust. Fits in nice and snug, no leaks from the rear seal after replacing it either!
Old May 2, 2020 | 08:50 PM
Looks good!
Tricked-Out-Toy
Apr 19, 2007 06:58 PM
99TransAmWS6
Apr 6, 2007 09:43 AM
RPWS6
Mar 18, 2006 06:58 AM
Lt1camroz28
Parts Wanted
Mar 3, 2005 04:24 PM
93M29FOURMULA
Nov 6, 2003 08:53 AM
