Lt1 camaro bogging problems
Old Sep 10, 2013 | 05:51 PM
Capnmike95's Avatar
1994 camaro z28 i have changed the optispark and water pump and wires and plugs cold air intake and it still has a problem with bogging. It's never really boys when cold and if I start first try it goes and starts if I shut it off and try again its take a little and when I drive it cold it drives fine and now lag. But when it's hot it bogs on take off 1000-2000 rpm if you give it regular gas but if you slightly push it it does bog as bad. It always done it since I bought the car and I've double checked every wire and plug. It seem to stay in bogging mode when it push to speed up and if you let it stay like that it will shake A little and surge. I have no idea what it could be. Please someone have this same problem who has fixed it
Old Sep 10, 2013 | 06:22 PM
Re: Lt1 camaro bogging problems
Have you checked the rubber intake elbow for tears, or the bottom lip not being over the throttle body?
Have you cleaned the MAF sensor?
Have you scanned it for codes and checked the fuel pressure?
Old Sep 10, 2013 | 06:56 PM
Capnmike95's Avatar
I've changed it with a brand new cold air intake and I've cleaned the maf and the rubber elbow is fine and not folded underneath the throttle body people say maye fuel filter or icm cooling mod.
Old Sep 10, 2013 | 08:41 PM
slick1hunting's Avatar
As said above have you scanned for codes? Checked fuel pressure? You say it seems to run fine when cold what amount of time (1-2 minutes or longer?) As that may point to heat sink or closed loop issue.
Old Sep 11, 2013 | 10:23 AM
Capnmike95's Avatar
Scanned and nothing is popping up and I didn't check the fuel pressure but supposaly it around 39-40psi I don't really know how to check it and yeah pretty much when the computer reads that everything is okay it start to run like ****
Old Sep 17, 2013 | 11:14 PM
eagle745's Avatar
Definetly check your fuel pressure. With the vacuum line off it should read 40+ @ idle. if its under 40, its possible fuel pump .It sounds like a fuel supply issue.. Good luck
Red Hawk 94
Mar 18, 2019 04:03 PM
bernie1951
Dec 10, 2014 10:03 AM
siguy
Nov 27, 2014 10:07 AM
1LEThumper
Jul 14, 2003 12:45 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
