LT1 "cam only" dyno record
Re: LT1 "cam only" dyno record
Originally Posted by Owens Racing™
Springs yes. Lifters are subject to the condition of the engine.
Originally Posted by ulakovic22
Personally I think that "cam only" should be just that, not "cam only" plus rockers, elec w/p, TB, exhaust, etc. The comment was made earlier that solid rollers don't count as "cam only" because you have to change the lifters as well. I think that's crap, if you can count supporting mods in "cam only" numbers then solid rollers should be allowed, esp since you have to R&R the lifters anyway.
Originally Posted by Chopstix
let me get this straight....if you replace your lifters because they are worn out it is O.K....but if you replace them because you want something better it is not.
Come on what does any of the parts in between cam and rockers have that would yeild a fantasatic gain over factory?
Honestly, you might loose a pony or two with them, cause your adding weight. Hardened pushrods, and beefy lifteres weigh more than stock. The more weight you gotta move around, the more power it takes. So busting someones ***** for changing lifters on a Cam Only car I think is kinda gay.
Originally Posted by mad scientist
You are not cam only if you have cam and lifters. Wouldn't that be "cam and lifters only" ??
What is the SAE record?
Then the car you are talking about isn't cam only. I'm sure it has exhaust, CAI, a tune, headers.
hey *****... bring that bitch down to louisiana and race frank and see what happens....
and yea a "cam only" car is a car with full bolt on's (lifters RR's etc) and a cam and UNTOUCHED HEADS! that is what a cam only car consists of. if u throw nitrous, a blower/turbo in the mix it isnt cam only nemore and if u touch the heads watsoever, it is not a "cam only car" nemore.
