LE2 cam install(2 question)
Old Jul 15, 2007 | 03:52 AM
always faster's Avatar
Since i need to tear the front of the car again to take off the timing to solve this: http://web.camaross.com/forums/showthread.php?t=531981
I told myself why not cam it
I will be installing:
1-LE2 Cam
8-Gm guide plate(14011051)
1 set-Comp cam pushrod(question about it)
1 set-Comp pro mag rocker(question about it)
1 set-Pac1218 or Pac1518(depend on the choice of rr)
1 set-4705-16 Seats
1 set-614-16 Locks 10*
1 set-795-16 Steel retainers
1 set-Timing cover gasket set
1 set-Intake gasket set
Rocker stud:
-What 7/16 rocker stud do i need p/n??
Pushrod question:
-My engine is new(lt4,195cc head,oversized valve)with all the supporting mods(Lt headers,cat less "y"pipe,32lbs injectors,52mm tb)so do i need stock length 1 pieces hardened 7.20" puhsrod or shorter?
Rocker question:
-I dont have the lift spec yet on the le2 cam but it similar to a cc306 one so around .510"/.540" with 1.5rr so that would give .544"/.576" with 1.6rr.My car is a street car with a lot of spirit but im trying to have some reliabillity.I was always told to keep the lift under .550" on the street to be safe.
So do i order some 1.5rr to keep it under .550" or i am gonna loose to much power and i should put some 1.6rr.
Old Jul 15, 2007 | 08:44 AM
Well i ve found the part number for the 7/16 stud: ARP134-7103.
So now just need answer on the rocker and the pushrod before ordering.
Old Jul 15, 2007 | 08:47 AM
mdacton's Avatar
you will be fine running the 1.6 rockers
you really need to put it all together and check PR length.......wrong PR can be 15 h.p
Search on how to check them then go from there, I won't tell you 7.2" is right cause it may work it may not
Old Jul 15, 2007 | 08:50 AM
Ok i ll take 1.6rr
The reason im asking about the puhsrod is because im from canada and ordering all my parts from the states(prices and services issue ) and i wanted to order everything in one shot.
But for 15hp i thonk that i will order a pushrod lenght checker and order the good one after.
Old Jul 15, 2007 | 08:52 AM
mdacton's Avatar
If the 7.2" ends up being what you need I have a new set in the box....if you need em, I know how shipping to canada is......USPS is the way to go
Old Jul 15, 2007 | 08:56 AM
How much and are those 1 piece quality one? ,just answer by pm
Old Jul 15, 2007 | 09:32 AM
OldSStroker's Avatar
1-LE2 Cam
1 set-4705-16 Seats
Rocker stud:
Pushrod question:
Rocker question:
All LE cams are designed to run with certain valvetrain parts. Ask Lloyd Elliott these questions if you buy the LE2 cam from him or he may suggest you ask SStrokerAce. That may or may not be a good cam for your combination, BTW.
Old Jul 15, 2007 | 09:42 AM
I wanted a cam with a lot of lope and good power.I was looking at a cc306 because it sound so mean but the torque curve under 3500rpm was kinda low.
I then see the le2 cam wich is very similar to a cc306 but give a lot more torque between the 2500/3500rpm band.
I know that i dont have the best head(stock lt4 one) but at least i got 25cc ,30cfm more and bigger valve than a stock lt1 one so i think that is the cam im looking for but i could be wrong.
I dont have bought it yet.Tommorrow is the buying day
Old Jul 15, 2007 | 12:15 PM
dangalla's Avatar
lloyd told me to get the trick flow guidplates, they are cheaper and alot of people are having issues with the gmpp not being hardened
guedplates - 30400623-8
and seriously, talk to lloyd, he is great about answering questions like these
mikey4play
Mar 15, 2015 11:45 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
