INTAKE MANIFOLD/gaskets
Old Apr 27, 2006 | 06:26 AM
RichyZ28's Avatar
im puting new gaskets on my intake, is there anything else you guys would do while i have most of this stuff off the motor?
also when i took the throttle boddy off it didn't look like any gasket sealer was used...im wondering if i should put some back on when i go to put it on.
also i have seen people put a intake filter on the valve cover and the left side on the throttle boddy, this better then haveing the air hose attached from thorttle to valve cover? or is it more for looks then anything?
Old Apr 27, 2006 | 09:02 AM
cjmatt's Avatar
Re: INTAKE MANIFOLD/gaskets
run to your local autoparts place and get this copper spray gasket sealer. they use it for turbo mounting flanges and high boost head gaskets on talon 2.0 turbos mostly. it works wonders. just spray an even coat and stick it down. i use it on all my gaskets
Old Apr 27, 2006 | 09:23 AM
Javier97Z28's Avatar
Moderator
Not necessary on LT1's, the gasket does a fine job.
Uh, while it's all apart? Sure, throw a cam in there Your halfway there :P
Just get a tube of permatex black RTV and make a nice bead on the front and back, you'll be all set.
Old Apr 27, 2006 | 12:10 PM
Kevin Blown 95 TA's Avatar
Like Cjmatt wrote, spray Coppercoat is a good idea for intake gaskets, waterpump gaskets, timing cover gaskets, etc. Sometimes putting them on dry works fine, other times you get to do it twice, and they can't be reused.
Old Apr 27, 2006 | 05:20 PM
RichyZ28's Avatar
i was thinking of porting/polish my intake a bit, but not sure how much to sand it down.
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
MadMav
Jun 15, 2015 09:51 PM
jwade88
Jun 14, 2015 09:38 PM
Countryboychevy
Jun 13, 2015 02:49 PM
maybe2fast
Mar 26, 2015 08:34 AM
