Installed the LTCC setup today!! WOW!!
Old Aug 24, 2003 | 09:32 PM
  #16
REPO's Avatar
The box is $399 from Bob, I got a set of LS1 coils from TByrne for $80! (off a car they were parting)
Old Aug 24, 2003 | 09:48 PM
  #17
818camaro95's Avatar
Let's get a Group Purchase going.
Old Aug 25, 2003 | 08:31 PM
  #18
arnie's Avatar
Originally posted by zuluman13
Will the optispark still break if water gets to it.
What the LTCC (LT coil conversion) does is remove the high secondary voltage (plug voltage) responsibility from the opti. It does this with 8 LS1 coils. Technically, what you end up with is a L(S)1 ignition conversion for the L(T)1. The opti, (or some replacement) is still needed for the high/low resolution signals. Sooooo, to answer your ?, yes, the basic shortcomings of moisture penetration still exist. However, as stated above, it removes the high voltage responsibility, and this does improve the durability of the opti, along with superior plug voltage.
mikey4play
Mar 15, 2015 11:45 AM
maybe2fast
Feb 5, 2015 05:14 AM
StngStlkr
Sep 6, 2002 05:47 PM
Evilfrog
Aug 7, 2002 11:36 PM
