Inline Fuel Pump
Old Aug 17, 2006 | 11:50 AM
jfbamf's Avatar
Inline Fuel Pump
Here is the question, Im installing a Powedyne supercharger, Now the questions I have is with the fuel system, I know i need to upgrade the fuel system. I cant spend alot of money because the Wife will catch on.. So Can I install a inline fuel pump to boost the pressure, with the stock pump still in the tank and working properly, I understand its not the best setup but will it work?
Old Aug 17, 2006 | 01:06 PM
jfbamf's Avatar
Re: Inline Fuel Pump
Any one?
Old Aug 17, 2006 | 03:24 PM
TransAm396's Avatar
yes, it will work.
Old Aug 17, 2006 | 03:33 PM
Adding the inline will work. The NOS dry kit comes with an inline pump, and I ran that for almost 5 years with no problems. Part of the answer as to the best way to do it depends on how you increase your fuel flow on boost. If you add the extra fuel using an FMU that boosts fuel pressure with boost, the inline pump will make it easier for your system to reach a higher pressure, while maintaining high flow.
Old Aug 17, 2006 | 11:51 PM
OBE1 95Z28's Avatar
In-line fuel pumps aren't cheap; my experience is that they cost about double that of an in-tank pump. Of course that's parts cost only and you have to do the labor.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
