I need help with my car please!
I just changed the fuel pump and the fuel filter last month and it's a higher pump because I am planing on putting a cam and bigger injectors and building my heads. And I checked to see if I had fuel even tho it reads 1/2 I went by the k.I.s.s method and eleminated some stuff.
The only way to prove the pump is good is with a gauge. Anyone who works on a modern car needs a fuel pressure test gauge in the toolbox. That, a multimeter and a scanner will help diagnose/troubleshoot most problems.
In any case, if several people suggest that you check the fuel pressure, rather than not respond at all, simply say "I don't have a gauge". That way we will know that you aren't going to check the pressure, and we can move on to another person's problem.
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
