I need help with my car please!
Old Feb 24, 2010 | 06:44 PM
  #16
Hasz28's Avatar
I just changed the fuel pump and the fuel filter last month and it's a higher pump because I am planing on putting a cam and bigger injectors and building my heads. And I checked to see if I had fuel even tho it reads 1/2 I went by the k.I.s.s method and eleminated some stuff.
Old Feb 25, 2010 | 07:16 PM
  #17
maddog05's Avatar
Try disconnecting the rubber elbow at the throttle body and squirt a little raw fuel in there...then, start it...if it firres right up you have fuel starvation if not you have a weak spark.
Old Feb 25, 2010 | 10:16 PM
  #18
Hasz28's Avatar
Thanks everyone for the help. But it was the hose on my fuel pump inside my tank that came off haha. But now I know some more stuff about my car. Thank you everyone that helped.
Old Feb 26, 2010 | 12:44 AM
  #19
I asked you twice if you had checked your fuel pressure, and others did to, but basically, you seemed to ignore all of us.
Old Feb 27, 2010 | 12:56 AM
  #20
Hasz28's Avatar
I don't have a gauge to test it. But I figured it did since it was runnin. My bad I wasn't ignoring you on purpose. But still thanks for the help.
Old Feb 27, 2010 | 09:15 AM
  #21
The only way to prove the pump is good is with a gauge. Anyone who works on a modern car needs a fuel pressure test gauge in the toolbox. That, a multimeter and a scanner will help diagnose/troubleshoot most problems.
Old Feb 27, 2010 | 05:30 PM
  #22
If I read your posts correctly, at this point its NOT runnin(g). Look at post #18. Did you consider that possibility?
In any case, if several people suggest that you check the fuel pressure, rather than not respond at all, simply say "I don't have a gauge". That way we will know that you aren't going to check the pressure, and we can move on to another person's problem.
Old Feb 28, 2010 | 06:40 AM
  #23
Hasz28's Avatar
Ok *** hole. I get. You don't have to make fun of the way I talk. And you don't have to keep being a sower puss "Fred" I didn't have a gauge so I did do what one of them said and poored some fuel in it.
Old Feb 28, 2010 | 06:48 AM
  #24
Hasz28's Avatar
Sour** just got off work.
Old Feb 28, 2010 | 10:34 AM
  #25
Well.... its clear that this thread is going nowhere.
What rock do these people crawl out from under?
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
