I Hate my Car!!!!!!!
Old Apr 16, 2005 | 06:59 AM
  #16
cb94ta's Avatar
Re: I Hate my Car!!!!!!!
Well I'm putting my lt's on soon and tuning it up while I do it, It doesn't sound like it but it is possible hopefully putting them on might help....
Old Apr 16, 2005 | 07:50 AM
  #17
Pit94z28's Avatar
The same thing happen to me. What i found was a cracked manifold on the passenger side.
Old Apr 16, 2005 | 08:02 AM
  #18
cb94ta's Avatar
Well unless i can figuer it out I'm gonna drive it till it grenades, gives me an excuse to build thge stroker motor I want, I'm looking to buy a block now so I can at least get started
Old Apr 16, 2005 | 11:03 AM
  #19
guywithaZ's Avatar
I have heard bad head gaskets knock like a rod...when they blow between the cylinders...of course it never goes away...but a bad HG can cause a knock...
Old Apr 16, 2005 | 11:11 AM
  #20
ShawnMacAnanny's Avatar
Same thing happened last weekend. I hear mine mainly at idle becuase my exhaust it loud but at the front of the engine you can hear a definate ticking. I adjusted the rockers and it went away a little. I still think i collapsed a lifter.
Old Apr 16, 2005 | 10:37 PM
  #21
cb94ta's Avatar
I used the matco combustion leak tester to see if I had a blown head gasket and it tested out fine, how can I tell if it's a collapsed lifter?
Old Apr 17, 2005 | 01:19 AM
  #22
hvyss's Avatar
My Impala did the same thing yesterday. After running it to town and back i shut it off and about an hour later I started it and there was an awful ticking noise. pulled the valve covers today and found a rocker arm(comp pro mag 1.6 S/A) loose on cylinder#4 exhaust. The funny thing was the nut was tight and so was the polly lock. This is with CC R lifters. I have heard terrible things about the R lifters lately here and on the Impala forum. Well I reset the lash (car running) and seems to be fine now so far, but if it comes back the lifter has failed and will replace all with something other ran the Comp R's. Good luck.
HVY SS
Old Apr 17, 2005 | 04:55 AM
  #23
Blownbird355's Avatar
Spun bearing and lifter or valvetrain noise sound alot alike.
LastChance719
Dec 3, 2014 07:55 PM
USAirman93
Nov 24, 2014 03:37 PM
regular Joe
Aug 10, 2002 07:15 PM
regular Joe
Aug 8, 2002 03:47 PM
regular Joe
Aug 8, 2002 07:53 AM
