How much harder is it to install 10.4mm wires than 8.5mm wires??
I really want to get the Taylor Thunder Volt 10.4mm plug wires with NGK TR55 plugs. I herd that they are a pain in the a## to install. I have a lift to work with though, so I'm not sure how difficult this may be. Any advise, tips, any info at all would be appreciated. Thanx!!!!
8.5 wires
i agree it's hard enough to loom 8.5's would not want to try 10.4's that and i dont see a big gain by going to the bigger wire every big cars ive seen from john force down to milt decker(fastest small block in the world) use the msd 8.5
I would say that if you're wanting to run 10.4mm wires, then you'll probably have to go over the valve covers with them.
When I installed my 8.5s, I had a heck of a time getting them into the stock routing behind the power steering pump, so I know 10.4s won't fit right through there anyway.
Good luck with them!
I agree, i had the 10.4 wires and i barely got them to go through on the passenger side. I bought headers, the made for you looms to go over the valves and went back to the 8.5 wires. The big wires looked cool but that's about all the difference i saw from them.
derick
derick
Originally posted by hozb817
Thanx for the advise but I have done my research and these wires are definatley better than 8.5mm wires!
Rich Krause
I'm not pullin' 800 ponies like some people
, but the stock type wires have been fine for me.
Alex Barnes
Jan 24, 2015 10:21 PM
ro2207
Dec 4, 2014 06:18 PM
