how much can I stroke??
Old Aug 21, 2004 | 05:17 PM
smokindastangs's Avatar
I need to know how much stroke LT1's can take.... I wanna go as big as possible and I realize that some grinding might have to be done; however, I don't want something that is not going to work at all. Thanks, Jason
Old Aug 21, 2004 | 10:50 PM
Re: how much can I stroke??
I've seen at least one person who used to post on CZ28.com fairly regularly claim he built a 421ci LT1 with a 4.030" bore and a 4.125" stroke - don't knwo if anyone actually saw it. I think that a 4.125" crank is going to stretch the limits of your definition of "some grinding"... even a 3.75" stroke crank requires "some grinding".
Old Aug 21, 2004 | 10:54 PM
rskrause's Avatar
Moderator
You can hit water even when clearancing for a 3.75" stroke, depending on the rods used and the variation between castings.
Rich Krause
Old Aug 21, 2004 | 11:21 PM
OK.... this belongs in "LT1 Engine Tech".... might want to combine it with your post about a 500(rw)HP naturally "asperiated" engine.....
Old Aug 22, 2004 | 12:39 AM
BlackLT1_TX's Avatar
im shocked nobody has mentioned the title of this post, "how much can I stroke??"
AHAHAA
Old Aug 22, 2004 | 12:55 AM
sorry you are right I should have combined the two questions....and no pun was intended by the title!! :-) Has anyone else ever heard of any luck w/ that 4.125 stroke?
Old Aug 22, 2004 | 12:59 AM
warwickbass's Avatar
Until it's raw.
Old Aug 22, 2004 | 01:53 AM
CoUnTryMuZiCZ28's Avatar
Originally Posted by warwickbass
Until it's raw.
AAHHAAHHAHHAHAHHAHAH
Old Aug 22, 2004 | 05:25 AM
rskrause's Avatar
Moderator
Very long strokes on a stock block are cost ineffective. Put the money into heads. If you really want to spend the long buck on an LT1 you could adapt some 18 or 15 degree heads and make some really big power. Or go all out with an aftermarket gen I small block and get some really big cubes. Just be sure to bring plenty money to the party. Unfortunately, you won't be leaving with it!
Rich
RUENUF
Mar 13, 2016 03:37 PM
Z Power
Sep 19, 2015 11:19 PM
smoknta
Aug 27, 2015 05:07 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
realistyc
Jul 28, 2015 07:32 PM
