how do i pull codes
Old 09-20-2003, 11:23 PM
ramair94ta's Avatar
how do i pull codes
my car seems to have a mis and back fired tonight and i want to see if there are any codes being set off, is there any way to check my codes like the older car and the ALDL.
thanks for any help
ramair94ta is offline
Old 09-21-2003, 12:57 AM
93 was the last year you could flash the codes on the SES light by shorting the pins in the ALDL connector. For 94/95 models, you need an OBD-I compatible scanner. Auto Xray is probably about the cheapest, at $170. Do not buy the $30 Actron, all that does is short the pins, so it won't work. But Actron does make several "real" OBD-I scanners for higher $$$$$.
Injuneer is offline
lt1matt
03-21-2015 07:35 PM
Fatdog2
02-13-2015 08:19 PM
Gtpguy
01-26-2015 04:50 PM
91Bird305
08-05-2002 01:39 PM
Darth Xed
13
07-22-2002 12:45 PM
Quick Reply: how do i pull codes
