how do i pull codes
my car seems to have a mis and back fired tonight and i want to see if there are any codes being set off, is there any way to check my codes like the older car and the ALDL.
thanks for any help |
93 was the last year you could flash the codes on the SES light by shorting the pins in the ALDL connector. For 94/95 models, you need an OBD-I compatible scanner. Auto Xray is probably about the cheapest, at $170. Do not buy the $30 Actron, all that does is short the pins, so it won't work. But Actron does make several "real" OBD-I scanners for higher $$$$$.
