how do i pull codes
how do i pull codes
my car seems to have a mis and back fired tonight and i want to see if there are any codes being set off, is there any way to check my codes like the older car and the ALDL.
thanks for any help
thanks for any help
93 was the last year you could flash the codes on the SES light by shorting the pins in the ALDL connector. For 94/95 models, you need an OBD-I compatible scanner. Auto Xray is probably about the cheapest, at $170. Do not buy the $30 Actron, all that does is short the pins, so it won't work. But Actron does make several "real" OBD-I scanners for higher $$$$$.
Gtpguy
01-26-2015 04:50 PM
Darth Xed
13
07-22-2002 12:45 PM
