Hooker shorties owners inside please
Old Apr 20, 2003 | 06:18 PM
danner's Avatar
Any tricks or suggestions on how to get the drivers side in. I did the passenger side first with logic getting the hard side in first. I am now on the drivers side - oil filter and all plugs and wires removed. Still unable to sqeeze it in there. Any helpful suggestions welcomed. Thanks in advance.
Old Apr 20, 2003 | 10:53 PM
Bud M's Avatar
It has to go in from the bottom. You will need to separate the steering column. If you have a 93 you will have to remove the oil pressure sender and the oil filter and there is another plug in the oil pan (I think) that has to be removed. Then it should go right into place.
Old Apr 21, 2003 | 05:36 AM
danner's Avatar
Thanks for the input, i was able to sqeeze it in with just loosening the steering linkage, removing oil filterand plugs and wires. I had it wrap well to prevent scratches. wish we had more room in these things.
Injuneer
Apr 25, 2022 06:22 PM
ducttape1975
Jul 10, 2015 06:29 PM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
smacz28
Aug 6, 2002 01:51 PM
ferraricameron
Jul 29, 2002 07:46 PM
