New track times, how do I improve 60ft???
Went to Bristol Dragway tonight (about 70° and humid!) and got in 9 runs with my new mods. New mods are in my sig.
Best Run:
R/T: .540 60': 2.268 1/4: 14.192@99.57
I was pretty happy with my times, but I feel with the mods I have, I can do better. I need to improve my 60' times the most. I am launching @ 2000 rpm with 30psi in the rear street tires, after doing a small burnout and staging shallow. I shift at about 5000 rpm. I am always spinning out of the hole. I would like the 60ft below 2.0sec. Does anyone have any advice on how to improve my 60' times, preferably besides more mods? Thanks for your advice.
1994 Z28
black, M6, t-tops, 85K
Falken ZE-502 tires, Hurst short throw shifter, !CAGS, SLP fan control switch, 2000 SS take-off exhaust
Latest mods: 160° thermostat, Lingenfelter CAI, 1LE intake elbow, SLP airfoil, Accel 300+ ignition, Accel Extreme 9000 wires, NGK TR55 plugs, Jet-Hot coated Hooker shorty headers, ALL SELF-INSTALLED
all Mobil 1 fluids
best stock times: R/T: .540, 60 ft: 2.268, 1/4: 14.192@99.57 mph
need better 60' times and traction...
Best Run:
1994 Z28
all Mobil 1 fluids
Yes i am having the same problem...i have a 96 t/a with an A4. The best 60' time that i could get was 2.178..i need this to be at least 1.9...how do i get it there? I am running Nitto extremes 285/40/zr17.
<font face="Verdana, Arial" size="2">Originally posted by blksunshine:
Uhh practice, and Drag radials.</font>
But ferra, are you running those times with ALL of whats in your sig? You should be trapping a little higher I would guess, but maybe I am wrong!
As for the better 60's, get some practice, or skip that part (sometimes it will NEVER happen on a sh!tty track) and get some drag radials. Then you will be wondering on how to MAKE them spin
Get a cutout on there by the way. You will like it. Kind of feels a tad bit slower off of the line (which can be good with no traction already) but you will pick up a few horses up top
good luck!
TONEZ28 - 97 Black Z28 A4 : 270rwhp/290rwtq
Mods : K&N CAI-Flowmaster-TB Bypass-Airfoil-160 Stat-Cutout-
!MAF Screen-Manual Fan Switch-TransGo Shift Kit-3.73's-BFG DR's (track use only)
(Hooker LT's collecting dust)
Appearance : 01' z28 Chrome 5 Spokes-GTS Blackouts-Billet Grill-
Orange Reflective z28 & Bowtie Overlays & Camaro Letters-Orange Tint
Best E.T. : 13.64 @101.50 w/ 2.04 60'
w/ Drag Radials : 13.56@100.80 w/ 1.97 60'
[This message has been edited by sfGi8nt (edited July 26, 2002).]
Find a nice deserted street somewhere and practice launching. You will be able to feel a good launch. Try getting into the gas a little slower and maybe launching at a slightly lower rpm. You could also buy a g-tech or similar device to practice your short times with.
Ensure your tires make maximum contact with the ground at the pressure you use. Regular street radial tires tend to get a cupped shape, bringing the centre off the ground when they're underinflated. The opposite occurs when they're overinflated (a good thing for the front tires at the track). Inflate your tires to ~35 and lay a little rubber. Read your tracks, looking to see if they're darker in the centre or outside edges. If they're dark in the centre, drop the pressure a little and lay some more rubber. Keep at it until you have a nice even contact patch.
[This message has been edited by Erik (edited July 27, 2002).]
<font face="Verdana, Arial" size="2">Originally posted by Erik:
[This message has been edited by Erik (edited July 27, 2002).]</font>
Rich Krause
'95 Z-28 383 with Vortech, nitrous, etc.
"1FASTZ28"
Your shifting at 5000rpms???? If so, you could be missing out on a lot of power. You need to shift at 5500rpms MINIMUM.
94 Formula-6spd, New Mods are cloyes double roller timing set, CSI WP, Opti conversion,PCMFORLESS tuning, Comp R lifters and cc306, Hurst Shifter, Hotchkis Control Arms and Panhard Rod, Moroso Cai, Msd Ignition, Flowmaster Exhaust, Mac Headers & y-pipe, offroad pipe, Crane 10308 spring kit, 1.6 Promagnum RR's
Dyno with headers and RR's!
297rwhp
328rwtq
13.2@112.65(stock heads, full weight, 92 degrees outside)
297rwhp
328rwtq
i find streets has much better traction than the track.
1993 Grabber Blue Mustang GT
Trick Flow Heads, Street Heat intake, 3/8in spacer, E303, TFS 1.7rr & 6.75 pushrods, Holley 190lph fuel pump, 24# injectors & sample tube, SVO timing chain, Aeromotive AFPR, 180* t-stat, 2 5/8 Auto Meter mech fuel pressure gauge, K&N, March Ram Air & Pullies, 73mm C&L MAF, Edelbrock 65mm TB & EGR, 1 5/8in Equal Length Super Competition Hooker Headers, 2 1/2in H-Pipe w/hi-flow cats & Flowmaster 2 1/2in Cat-Back Exhaust, FlowTech Cut-Outs, Nitto DR's, 3.73 gears, FMS Aluminum DriveShaft, Pro 5.0 Shifter, Pro-Shift Lite, 8.5mm MSD Super Cunductor Plug Wires, PowerSlot rotors, PowerMaster 140amp Alt., LX lights, Cobra R hood w/SVO scoop, Saleen spoiler, Cobra Bumper, 3in chrome tips.
13.007 @ 108.39 w/ 2.149 60'
Whoops, I meant to say I shift at 5500. my rev-limiter is set at 5750.
1994 Z28
all Mobil 1 fluids
1994 Z28
all Mobil 1 fluids
Tires and practice, at the track where conditions are designed for racing. You need a good sixty foot but you also need a good reaction time.
'94 Black Z28, 383, 700R4
1/8 ET: 7.49
1/4 ET: 11.86
1/4 MPH: 112
http://www.downtime.cz28.com.index.html
1/8 ET: 7.49
1/4 ET: 11.86
1/4 MPH: 112
teedoff59
Aug 8, 2002 01:36 AM
