HMMMM another problem
Old Aug 14, 2008 | 06:40 PM
mr.green's Avatar
ok im having a lil problem....my car is cutting out a little bit when i give it full throttle...but it dosent do it all the time maybe staving for fuel??? also when i do give it WOT or do a pull in gear it seems like a fly can push the pedal down any thoughts or suggestions.......also why is the lt4km better than the lt1??
Old Aug 15, 2008 | 04:05 PM
mr.green's Avatar
does noone here no the problems with my car
Old Aug 15, 2008 | 10:13 PM
seawolf06's Avatar
You'll have to hook up a fuel pressure gauge and do a WOT run to see if you're losing pressure. If it's cutting out, I'd be inclined to say it's ignition related.
You're saying the pedal is only hard to push 1/2 of the way and then it feels like it comes loose? Or do you just mash it and not realize what you're doing?
Your TB cable or the TB itself could need adjustment. We can't solve your problems online.
Old Aug 15, 2008 | 10:39 PM
Is it actually "cutting out" - completely losing power, like the ignition was shut off, or is it more like a "stutter" or a misfire? Is there some particular RPM, or an RPM/gear combination where this happens?
The LT4 knock module is designed to filter out the mechanical noise caused by the Crane Gold roller rockers used on the LT4 engine, and prevent that signal from reaching the PCM and causing knock retard.
Old Aug 16, 2008 | 12:22 AM
mr.green's Avatar
idk its like it bucks and jumps and mainly in first gear . or when i give it a fair amount of pedel with rps around 2200-2600
Old Aug 16, 2008 | 06:14 AM
Check the rubber inlet elbow (between the MAF sensor and throttle body) for tears, or for the bottom not fully on the throttle body.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
Caps94ZODG
9
Jul 26, 2002 03:36 PM
