HMMMM another problem
ok im having a lil problem....my car is cutting out a little bit when i give it full throttle...but it dosent do it all the time maybe staving for fuel??? also when i do give it WOT or do a pull in gear it seems like a fly can push the pedal down any thoughts or suggestions.......also why is the lt4km better than the lt1??
You'll have to hook up a fuel pressure gauge and do a WOT run to see if you're losing pressure. If it's cutting out, I'd be inclined to say it's ignition related.
You're saying the pedal is only hard to push 1/2 of the way and then it feels like it comes loose? Or do you just mash it and not realize what you're doing?
Your TB cable or the TB itself could need adjustment. We can't solve your problems online.
The LT4 knock module is designed to filter out the mechanical noise caused by the Crane Gold roller rockers used on the LT4 engine, and prevent that signal from reaching the PCM and causing knock retard.
taner
Sep 9, 2002 11:36 PM
Caps94ZODG
9
Jul 26, 2002 03:36 PM
