high idle
Old Aug 26, 2010 | 10:15 PM
bazzi's Avatar
high idle
Hello all,
So let me catch you up to speed, my water pump went so i put an electric one in.....Now so some reason my car idles high, like between 1500-2000! Now i think i might know what the problem is but i want clarification. My throttle body bolts are not long enough cause of the nitrous plate in between the intake and the throttle body and it seems like the top and bottom bolts on the driver side are striped and i cant get them tight. Would that cause my high idle? Or is it a sensor?
Thanks for your help
Old Aug 27, 2010 | 05:23 AM
High idle is caused by too much air getting past the throttle body. If you have a loose connection between the throttle body/nitrous plate/intake manifold you have a vacuum leak. Is it possible the nitrous plate is interfering with the blades closing?
Old Aug 27, 2010 | 12:28 PM
sepno77's Avatar
Originally Posted by bazzi
Hello all,
Yes, that can cause high idle along w/ any vacuum leak your motor might have.
ad356
Apr 11, 2015 08:49 AM
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
ChrisFrez
Mar 1, 2015 01:33 PM
IRABuss
Sep 7, 2011 09:08 PM
