Heads from a Bird to a Vette
Old Mar 26, 2011 | 12:30 AM
GS4-LT1's Avatar
Hey guys,
Thinking of getting a set of ported LT1 heads for my 94 Vette that where on a Firebird. Was there any difference between the two Bird and Vette heads? Will the alternator, compressor etc bolt up as should be on an LT1 vette. Thanks for the Help!!!
Old Mar 26, 2011 | 01:49 AM
henryz28's Avatar
Re: Heads from a Bird to a Vette
They are the same as long as it is a lt1 Vette; could be a lt4 with a orange/red intake manifold. If you don't have the orange/red looking intake then the Firebird bird heads will work.
Old Mar 26, 2011 | 06:36 AM
The LT4 was only used in the 1996 Corvette. He has a 94. If its an original Corvette engine for that year, its an LT1 and the same heads are used on the Corvette and F-Body applications.
The alternator and other accessories bolt to the mounting bracket that bolts to the front of the block, not to the heads, so nothing will change if all you are swapping is the heads.
Old Mar 26, 2011 | 02:15 PM
GS4-LT1's Avatar
Sounds good, Thanks for the info !!!
Old Mar 26, 2011 | 04:13 PM
Stl94LT1's Avatar
Temp gauge sensor placement is the only difference.
97ChameleonTA
Jun 4, 2015 08:19 AM
QuickSilver02
Apr 7, 2015 11:12 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
formula79
9
Jul 4, 2002 02:46 AM
