Guideplates question
Old Feb 24, 2004 | 11:25 AM
30thannZ28's Avatar
ok guys, I'm trying to reassemble my valvetrain, and I have few questions.
1. Should I install my guideplates while the heads are off the car or on?
2. I know I need hardened pushrods, but when I "rubbed" a stock pushrod against the seemingly harsh guideplate, it SERIOUSLY scraped up the stock pushrod, which scared me. Will it be safe (i.e. not scratch up) the hardened ones?
3. I bought a tap and the bit 7/16"-14 to clean out the head bolt holes, but the guy at sears said he has never heard of "thread chaser" and the tap should work even though he knew I didn't want to cut new threads. Was he right??
thanks!
Old Feb 24, 2004 | 01:07 PM
30thannZ28's Avatar
TTT
come on, someone chime in...
shoebox???
injuneer??
Old Feb 24, 2004 | 01:10 PM
1. It is easiest when the head is secured, because the torque for the stud is 50 lb. ft. Your call on whether you want to do it out of the car and can hold the head still. You should be using GM p/n 14011051 guideplates.
2. Hardened pushrods will be fine.
3. Yes, there really is a thread chaser. The Sears guy should get out more often.
Old Feb 24, 2004 | 06:28 PM
12SCNDZ's Avatar
Um...A few things here. First of all, the "threads" in the LT1 are "heli-coiled", with steel inserts, from the factory. I'm not even sure if it's safe to rechase them.
Second, you HAVE to install the plates once the heads are on, so you can align the rocker tips on the valves. All plates have some lateral movement.
Last...AND MOST IMPORTANT!. Make sure you've got the right guide plates. GMPP (GM Performance Parts) is the only manufactuerer that makes the right ones for LT1's. No COMP, Crane, or ANY OTHER will work! I'm just trying to save you some aggrivation and broken parts.
Frank
Old Nov 20, 2004 | 03:16 PM
Jeff95TA's Avatar
Re: Guideplates question
Should the roller be centered on the valve?
Old Nov 20, 2004 | 05:59 PM
12SCNDZ's Avatar
Yes, but you'll notice that some still aren't perfectly aligned.
Frank
Old Nov 20, 2004 | 07:19 PM
SS MPSTR's Avatar
Frank,
Does this apply to the LT4 heads too?
jasonduaine
Mar 7, 2015 09:44 AM
Catmaigne
Dec 25, 2014 12:16 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
