Good or bad ideal?
Old May 11, 2011 | 02:25 AM
thegeovonn's Avatar
Good or bad ideal?
Hay what do you all think I got 96 lt1 camaro A4 getting ready to install a set of pacesetter longtube headers and a magnaflow catback system also plugs & wires and i'm pulling the engine out from the bottom it look like it's the best way to go to install all this what do you all think and what should I look out for any info will help thanks
Old May 11, 2011 | 10:15 AM
95TA04GOAT's Avatar
Re: Good or bad ideal?
You're creating a lot more work for your self by pulling the motor to install headers. You'll have to lift the motor a bit to get the headers in but that's far from actually removing it. You wouldn't be able to install the motor from the top with the headers bolted on. So if you're set on removing it, out the bottom is you're only option.
Old May 11, 2011 | 10:24 AM
thegeovonn's Avatar
Yep! set on taking it out from the bottom also I while i'm at it I think it would better to do some other things while it's out could be wrong?
Old May 12, 2011 | 07:21 AM
Makes no sense at all to pull the eninge to do headers, but you've already made up your mind..... so what exactly is your question?
Old May 12, 2011 | 09:41 AM
thegeovonn's Avatar
Well I here how long it take to put headers on and spark plugs in so I feel in that amount of time I can have the engine out and no I not just doing headers! just was looking for some insight
Old May 12, 2011 | 09:43 AM
RamAir95TA's Avatar
Leave the engine in the car.
Old May 12, 2011 | 11:19 AM
After you unbolt the the manifolds, and while installing the headers, plugs and wires become very simple.
Old May 12, 2011 | 12:41 PM
thegeovonn's Avatar
Hay thank's for the info that's what I was looking for and sorry if I was unclear
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
InfernalVortex
Jan 17, 2015 09:35 AM
kizz
18
Mar 16, 2004 10:41 AM
Fbodfather
25
Jun 21, 2002 04:12 PM
