Getting Code 48: "MAF System Fail" - What besides the obvious?
Old Jul 5, 2006 | 10:41 PM
Dave88LX's Avatar
I got my AKM cable in and Datamaster today and was playing around with it doing a log. It shows a code 48 - MAF System Fail. Besides and obvious faulty MAF, what else could cause this? All fuses are good I already checked them. It's plugged in good. I asked on a local town forum if anyone had a MAF I could swap in to see if that was the issue.
Would this be a reason why it ran great then started running like ***?
What can I check or test?
Old Jul 5, 2006 | 10:47 PM
Dave88LX's Avatar
Re: Getting Code 48: "MAF System Fail" - What besides the obvious?
http://paradox.shacknet.nu/dave88lx/...es/383test.uni
Old Jul 6, 2006 | 05:30 AM
Guest47904's Avatar
Guest
Easy enough to check. Terminal C (pink wire) to terminal B (black/white wire) will measure 12 volts DC with KOEO. The yellow wire when measured to the black/white wire will measure between 4 and 6 volts DC.
If they all check out, put the meter on the wires so you can "wiggle" the wires while you check the readings.
Old Jul 6, 2006 | 07:50 AM
Dave88LX's Avatar
Cool I'll check it out tonight thanks.
Old Jul 6, 2006 | 11:35 PM
Dave88LX's Avatar
OK....
I have 13.xxV across the black/white and pink.
I have 6.3-7V between the yellow and black/white wire. Is that still OK? Or, do I have a problem somewhere else?
Old Jul 6, 2006 | 11:50 PM
Dave88LX's Avatar
OK tried the new MAF, still getting a Code 48?!?
Old Jul 6, 2006 | 11:58 PM
Are you sure the connector pins aren't bent or broken?
Old Jul 7, 2006 | 12:14 AM
Dave88LX's Avatar
No...because when I checked the voltage, I stuck my multimeter into the end of the connector...
Car won't start now either. Started once, stumbled, hitting the gas pedal didn't change anything, it was all it had to stay stumbling, no rev or nothing.
Old Jul 7, 2006 | 12:18 AM
Z28LT1_Just_Nasty's Avatar
Had that problem once, turned out I "thought" I had a good connection but it wasn't plugged in COMPLETELY. I also checked it a few times. Best advice I can give is check all the lines even leading up to ecu.
Old Jul 7, 2006 | 12:31 AM
Dave88LX's Avatar
MMmmm....why doesn't someone just buy it instead.
I need to stick to Fords.
DirtyDaveW
Dec 1, 2016 05:37 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Jul 4, 2005 05:00 PM
