Fuel Pump
Old Jan 21, 2006 | 10:07 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Fuel Pump
Well I think its finally that time.... This one had a good 11 year run but my car is cutting out and going really lean sometimes(sporadically) at wide open throttle and high rpms. New opti, wires, icm, ignition switch, coil, the whole works... Haven't tested my fuel pressure but I can't think of anything else it could be. So my question is, what is a good fuel pump for our cars??
Old Jan 22, 2006 | 12:45 AM
sssalah's Avatar
Re: Fuel Pump
Can't go wrong with the Walbro pump. Racetronix sells it with a nice installation kit for our cars for a true bolt in installation.
Old Jan 22, 2006 | 04:10 AM
Re: Fuel Pump
Where can I get the Walbro?? Tbyrne or Thunder Racing?
Old Jan 22, 2006 | 07:44 AM
bus-a-cap's Avatar
Re: Fuel Pump
You shot gun the entire ignition system. Then you come to the conclusion that it's the fuel system. Someone tells you what to buy and where to buy it and you still ask where to buy it. On top of all that, you never even test the pressure which is what you should have done in the first place.
I noticed you go to school at Texas State, must not be an economics major.
Old Jan 22, 2006 | 12:54 PM
Re: Fuel Pump
Uh alright ********, i'm just trying to figure out whats wrong with my car. Unless you have something constructive to add, why don't you STFU.
Old Jan 22, 2006 | 01:00 PM
Josh 94Z's Avatar
Re: Fuel Pump
I would highly recommend checking your fuel pressure before undertaking a pump replacement. (Unless you just want to in preperation for future mods.) 1st change your fuel filter if you haven't already. You can buy a fuel pressure gage at autozone fairly cheaply and hook it onto the schrader valve on the fuel rail.
Old Jan 22, 2006 | 01:02 PM
Re: Fuel Pump
I was thinking about doing it in prep for the future like you said... What horsepower does or stock pump take us too?? I'm at about 400 rear wheel right now and i have been told that I am pushing it with our stock fuel setups... Any ideas?
Old Jan 22, 2006 | 01:03 PM
2000GTP's Avatar
Re: Fuel Pump
I got the Racetronix fuel pump from Thunder Racing for 160.00. Plus they had a sale going on at the time so I saved a few extra bucks as well.
Old Jan 22, 2006 | 01:14 PM
Josh 94Z's Avatar
Re: Fuel Pump
400RWHP is probably overtaxing the stock pump, especially an 11 year old one. As mentioned above, everyone seems to like the racetronix setup.
Old Jan 22, 2006 | 01:53 PM
blazzinbird's Avatar
Re: Fuel Pump
i bought a walbro one from ebay 99 dollars
Old Jan 23, 2006 | 09:13 AM
jerrysta's Avatar
Re: Fuel Pump
I also got the ebay pump. Very easy install. All you have to do with a regular pump is modify the bucket a litte, although some guys get rid of the bucket. I did not want to do that so I shaved the ridges on the inside of the bucket a little bit so that the pump would sit straight up and not tip. Then glue the top of the bucket back on.
It was easy enough to me where I would have been upset to spend 60 bucks more just to avoid that work.
Old Jan 23, 2006 | 11:20 AM
Dansean1's Avatar
Re: Fuel Pump
Go thru Walbro's site, google it.
Walbro sells go stuff. I believe their pumps are in the new Ford SVT stuff.
I advise on buying the 255 lph in tank for just over $100. Supports good hp. Contact them.
Old Jan 23, 2006 | 11:43 AM
FastZinTennessee's Avatar
Re: Fuel Pump
With 3 posts your opinion means absolutely jack s*** here. Go fist yourself, newbie.
Edit: so I can make this helpful too- I got my pump from racetronix, I did have to do a little modification to the stock bucket that the pump fits in, otherwise it was pretty straightforward.
Old Jan 23, 2006 | 02:31 PM
Re: Fuel Pump
Thanks for all the help fellas... Don't know what I would do without this site... I ordered the racetronix this morning. Hopefully this will take care of my problem!
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
