Fronnt crank seal replacement
Old Mar 4, 2005 | 07:00 AM
Pig Pen's Avatar
I'm going to replace the front crank seal this weekend. Is there anything else, like other gaskets etc., that I will need when I replace this. I dont know what all needs to come off before this, like maybe something else with a gasket that should be replaced at the same time.
Thanks alot
Old Mar 4, 2005 | 10:42 AM
All4Chevy's Avatar
Re: Fronnt crank seal replacement
Yes, while you are pulling your seal out....make sure you replace mine too, it leaks oil
Bill
Old Mar 4, 2005 | 10:46 AM
There are no other gaskets needed. If you had other leaks, more stuff would have to be removed to get to them.
Old Mar 4, 2005 | 01:41 PM
Pig Pen's Avatar
Thanks alot Shoebox.
Old Mar 4, 2005 | 02:58 PM
tanker's Avatar
Most of the time it is oil coming from water pump or opti seal, and going down to look lik it is front crank seal. Get the same diameter as crank seal exhaust pipe from any parts store ($3), it will save you lots of time tapping the seal in. Also you will need a gasket puller, the old gasket is kind of impossible to remove without one. Hope this helps
Old Mar 4, 2005 | 03:00 PM
OBE1 95Z28's Avatar
Another vote that your leak is coming from the waterpump seal!
Old Mar 4, 2005 | 10:20 PM
dirtybird96's Avatar
The front of my intake was leaking and the oil was running down to the crank. Just another thought.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
1LEThumper
Jul 14, 2003 12:45 PM
