FAST with opti and or LTCC?
Old Nov 7, 2005 | 11:24 PM
1995ta's Avatar
Can I use an Opti with my FAST system? What about using LTCC instead? If I use the LTCC will I need to use a HAL effect crank sensor? Im new to all of this so any help is appreciated greatly...
Bret
Old Nov 8, 2005 | 06:34 AM
Dave89IROC's Avatar
Re: FAST with opti and or LTCC?
LTCC needs a opti
Old Nov 8, 2005 | 07:26 AM
The current FAST system will interface with the Optispark optical sensor. It has to be configured that way from the factory. You should be able to drive multiple coils with their eDIS unit.
If you only use a crank sensor, you will be limited to bank-to-bank injection, and a single coil or 4-coil "waste spark" ignition system.
Old Nov 8, 2005 | 08:03 PM
1995ta's Avatar
So I dont have to buy anything extra for my FAST in order to use my opti or the LTCC?
Old Nov 8, 2005 | 08:49 PM
bdc95ta's Avatar
yes you can run the ltcc w/ the fast system.
-brandon
maybe2fast
Apr 23, 2015 08:55 AM
maybe2fast
Mar 16, 2015 09:45 AM
mikey4play
Mar 15, 2015 11:45 AM
maybe2fast
Feb 5, 2015 05:14 AM
blksgZ28
Aug 2, 2002 03:09 PM
