Fans wont turn on
Old Jul 17, 2008 | 09:40 PM
darlandz's Avatar
Fans wont turn on
I have a 95 z28 its an auto and my fans wont turn on? i need help
i took the relays out and disconnected the fans and plugged them all back in and it worked one time after that and now it dosent again....
Old Jul 17, 2008 | 10:41 PM
96' Formula WS6's Avatar
Check to see if they turn on when you turn the ac on. If not then its time to check fuses and such
Old Jul 18, 2008 | 12:22 AM
IPrice's Avatar
K.I.S.S.
Find the fuses, find the problem.
-Ivan
Old Jul 18, 2008 | 05:28 AM
There is a fusible link in the power supply to the fans. Did you try swapping the relays in the under hood box, in case one of them is bad? What is the coolant temp getting up to, without the fans coming on? Is it possible you have a problem with the coolant temp sensor in the water pump housing? Have you scanned it?
Old Jul 18, 2008 | 12:57 PM
tlillard23's Avatar
why did you unplug them?
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
mspennyhughes
Mar 1, 2015 03:50 PM
Jul 4, 2005 05:00 PM
formula79
26
Aug 5, 2002 12:21 PM
