Building a "Pro-Touring" LT1, need opinions on combinations!!!
Old Jul 16, 2008 | 09:29 PM
94Z28rag's Avatar
Question Building a "Pro-Touring" LT1, need opinions on combinations!!!
I have been in the LT1 game for about 7 years now and am at the point to start planning my "LT1 build."
The car is a 1994 Z28 Camaro convertible that has recently undergone a 4L60E--->T56 swap. The car has the usual slew of bolt-ons including intake, exhaust, PCMforless, Eibach Pro-Kit, and other misc add ons. The back seats have been removed (for good) and plans are for a 6-point cage before anything else.
I have been toying around with the idea of a professionally-built forged 355ci LT1 with an LE3 package and a D1SC supercharger to finish off the performance under the hood, but the combination just seems too "commonplace" to me. I LOVE the power it makes, as 500-600 RWHP is my goal for the initial combo.
So I pose to you my question:
I want a rare, head turning, cool LT1 combination that makes good power and turns heads. I will be driving this car for pleasure on weekends as well as drag racing and rare road racing for fun. The car WILL be run hard. I can't stress that enough, and the drivetrain will be built to handle the abuse. I don't care about MPG, but it must be run on 93 octane pump gas. Consider supporting mods a given...but if you had between $10k and $15 to spend under the hood to accomplish my objectives, what could you cook up????
Thanks in advance guys!
If this should be in Advanced Tech, Please move it to that section.
Old Jul 16, 2008 | 09:38 PM
MarcR94v6's Avatar
Not to nitpick, but "pro-touring" means a road racer. So if you plan on doing more drag racing, you'll limit your handling capabilities by setting the car up for drag, but I realize you're talking about engine stuff in here.
You want head turning? Big lopey cam, loud exhaust does the trick. Put on some minor appearance mods that not many people have, like an LT1 SS spoiler.
As for 15k, you may go over that a bit if you had the superhcarger, assuming the work is being done at a shop, and not by you.
Old Jul 16, 2008 | 10:04 PM
94Z28rag's Avatar
I interpret "Pro-Touring" to be an "All-Around" racecar, and maybe I've been mistaken in my definition of such. In any case, I understand your suggestions of a big lopey cam, etc, but that can be done with any motor. I want an engine combo that is something out of the ordinary, what is a cool combo that you don't see very often? I'm just throwing this idea out there to poke and prod the mind of my fellow LT1 owners out there, all suggestions/comments/flames are welcome.
Good idea with the LT1 SS spoiler, and that is already something I've been considering as a niche appearance mod, and thank you for solidifying that as a definite mod to the car!
The car will have a Hooker Cat-Back exhaust with dual electric cutouts custom made at the collectors of each of the two long tube headers.
Old Jul 16, 2008 | 10:35 PM
MarcR94v6's Avatar
if you don't have a smog issue where you live, a single plane intake setup comes to mind, people making big power from those recently with raised runner heads. Using either a carb or fuel injected tb with an old style distributor.
Old Jul 16, 2008 | 10:47 PM
95z28man's Avatar
I can tell you I'm having a forged 383 LT1 built with KYB struts and mounts, 4 bolt mains, ported heads, intake and matched cam built for nitrous. Along with a built 4L60E from Performabuilt to handle 700rwhp, and 255 fuel pump, r&r on the gas tank, and some other little goodies basically adding up to a complete engine. This whole setup is costing slightly over 10 grand for parts, labor and tune. The nitrous will be added later. The good thing about nitrous is you have it whenever you want it (assuming you keep the bottle full), but then it doesn't constantly have the motor under that extra stress of a blower. You could however, build the motor for a blower... but that could easily cost you over 15 grand plus the cost of the motor... Not to mention you'll need a rear end that can handle it as well.
Old Jul 16, 2008 | 10:58 PM
'94 Bad A Z28's Avatar
D1SC too "common" for you? Then go ahead and do a F1R or a F3.
Old Jul 16, 2008 | 11:12 PM
Albone's Avatar
turbo
Old Jul 16, 2008 | 11:17 PM
94Z28rag's Avatar
Smog will not be an issue, as the car will soon be registered with a Classic plate.
Old Jul 16, 2008 | 11:19 PM
94Z28rag's Avatar
The rear end, etc will be able to handle a pounding. Thanks for the specs on your setup! Nice combo!
Old Jul 16, 2008 | 11:21 PM
94Z28rag's Avatar
True, but I don't initially want the output of those setups, and the D1SC can be upgraded to those easily. I'm not sure if turbo is the option, as I'm unfamiliar with these setups on LT1s for street/strip use.
Old Jul 16, 2008 | 11:22 PM
Doesn't a car have to be 20 years old to qualify for a classic plate?
Old Jul 16, 2008 | 11:26 PM
94Z28rag's Avatar
15 years old in Pennsylvania for a Classic plate. http://www.dmv.org/pa-pennsylvania/license-plates.php
Antique is 25 years old.
Old Jul 16, 2008 | 11:30 PM
Oh-well... no emissions here anyways so nothing to worry about, lol.
Old Jul 16, 2008 | 11:32 PM
94Z28rag's Avatar
Also, if you're under 5,000 mi per year in PA, no emissions is necessary.
Old Jul 17, 2008 | 11:29 AM
slomarao's Avatar
If you want something that no one has build a twin turbo setup. Very few out there. Want to make the TT setup even harder, keep the AC. even less room to work with.
Next would be a 400+ cube LT1, very very few of these around. If you wouldnt be doing the work the budget may be thrown out the window. This is going to be hard to do because of how easy it is to hit water in a LT block.
Lastly, build a sb2 or something with converted heads and intake. The sb2 would the fastest and prolly the most expensive but you could get a set of 15 or 18 degree heads and a victor jr. intake. Throw in a solid roller and spin it to the moon.
Thats about if for out of the ordinary, all will cost way more than a le3/d1 setup.
