ever had any problems with this?
Old May 18, 2007 | 07:18 PM
BlkZ28Kreepn's Avatar
http://store.summitracing.com/partde...0&autoview=sku
im planning on getting this, the stock one cost me 100 bucks this ones cheaper and looks better i think..Anyway it says fits SLP airfoils,my question is.I got the k&n kit coming down the fender, would it be a problem? or is anyone else using this with a k&n?
Old May 18, 2007 | 07:31 PM
2000GTP's Avatar
What year is your car? On my car, the cold air intake is a non-issue because the elbow connects the the MAF sensor which then connects to the intake. It is a good quality piece, there are no gains to be had with it, but it is a very nice appearance upgrade.
Old May 18, 2007 | 07:43 PM
oh yeah sorry that woulda helped huh, its a 94 camaro..thanks for the quick response man..yeah , i didnt expect gains i just saw it cheaper and looks cleaner then the stock one..and they want 100 for the stock one so, i rather go different..think i'll be ok with this piece? 94 camaro.
Old May 18, 2007 | 07:48 PM
2000GTP's Avatar
You'll be fine, that is what I have and it hasn't caused me any issues. It is a nice looking, solid piece.
Old May 18, 2007 | 07:50 PM
Kyle94Z28's Avatar
I know I'm new, but just to chime in, I do have that exact same piece on my 94 Z, and it fits fine (including airfoil), with all accessories necessary to install it. Only thing I have noticed is a tad bit more noise when you get on it, but as many have said, that's a plus.
Old May 18, 2007 | 07:54 PM
2000GTP's Avatar
Thats partially the purpose though too, it deletes the resonator that the factory intake elbow has. The resonator helps keep down intake noise.
Old May 18, 2007 | 08:04 PM
cool, thanks for the quick reply's..
Old May 19, 2007 | 07:36 AM
Sounds like you're getting your price from a local dealer - big mistake. A stock intake elbow, either with or without (1LE) the silencer tube should NOT cost you anywhere near $100. Try one of the sources listed on Shoebox's Tech Pages for discount GM parts:
http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason
Old May 19, 2007 | 05:09 PM
NovaTodd's Avatar
I have that elbow. It works fine but it does heat soak badly. It is fine for most drivng but does not like to cool down at the drags
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
