Engine slap?
Old Oct 7, 2004 | 01:19 PM
  #16
WS Sick's Avatar
Re: Engine slap?
If it is that noticeable, I would try to norrow it down to a point in the motor, then yank the intake and take a look at those lifters in that area, look over the cam etc. then button it back up and see.
Oilo additives are a temp fix, but if its a sticky lifty (disk inside lifter not responding etc) then they can "loosen" it.
Old Oct 7, 2004 | 01:20 PM
  #17
biltLT1's Avatar
Re: Engine slap?
Mine started doing that. Only after it warmed up. Kinda subtle sound. It turned out to be the #8 rod knocking. I had to pull the motor out of it and put a new crank and bearings in.
And YES, it will affect your performance because the knock sensor picks it up and retards the timing. Makes it run like a dog.
Old Oct 7, 2004 | 09:17 PM
  #18
ChrisUlrich's Avatar
Re: Engine slap?
Car runs great... picksup fine and cruises no problem. So you think I should just try the Slick500? Should I do an oil change asap? Because I just did one less then 2 weeks ago
Old Oct 7, 2004 | 09:19 PM
  #19
Re: Engine slap?
Also, car sounds NOTHING like the audio sample from Shoebox... it sounds like a clock ticking... very subtle and weak but noticable.
Old Oct 8, 2004 | 08:47 AM
  #20
Re: Engine slap?
No one?
Old Oct 8, 2004 | 08:48 AM
  #21
Re: Engine slap?
You said the knock sensor picks it up... but I got the OBD1 conversion, doesn't that conversion turn that sensor off?
Old Oct 8, 2004 | 08:55 AM
  #22
WS Sick's Avatar
Re: Engine slap?
No OBD1 uses the Knock sensor as well.
A clock tick does sound more like valvetrain.
Old Oct 8, 2004 | 05:43 PM
  #23
Re: Engine slap?
So if is no knock sensor... it wouldn't pick up the knocks and retard my timing giving me very poor performance... right?
Old Oct 8, 2004 | 07:37 PM
  #24
jdizzell's Avatar
Re: Engine slap?
You have a knock sensor and unless someone programed it out your pcm, your pcm will retard timing if you have vavle tap.
ChrisFrez
Dec 15, 2014 03:09 PM
Caps94ZODG
25
Oct 2, 2003 06:30 AM
Mikes25thAnnTA
Jul 16, 2002 12:44 PM
THE Z-MAN
19
Jul 8, 2002 04:04 PM
