engine seems to be misfiring
Old May 26, 2007 | 10:02 AM
matsgrn95z28's Avatar
I just spent two grand on a full tune up and clutch kit as well as a ton of seals and stuff. the car ran great the first few days I got it back but now I hear air being pulled from somewhere under the hood and the engine acts like it has several fouled plugs. The mechanic put R and R plugs on and other good parts. Is this vacuum related or a dead cylinder?
Old May 26, 2007 | 10:11 AM
Z28LT1_Just_Nasty's Avatar
Two grand on a full tune up? Sounds like you got robbed my friend, and from a bad mechanic too.
Well first things first:
Scan for codes
Check your wires
Check fuel pressure
Check that ICM is getting signal to fire
Check opti
Old May 26, 2007 | 10:55 AM
Check for a vacuum leak.... if you hear air flowing under the hood, track it down. Could be as simple as the intake elbow being torn, or slipping off the throttel body.
AdsoYo
May 2, 2018 03:21 AM
Klypto
Mar 23, 2016 09:05 AM
PCLZ28
Dec 24, 2015 05:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
