engine seems to be misfiring
I just spent two grand on a full tune up and clutch kit as well as a ton of seals and stuff. the car ran great the first few days I got it back but now I hear air being pulled from somewhere under the hood and the engine acts like it has several fouled plugs. The mechanic put R and R plugs on and other good parts. Is this vacuum related or a dead cylinder?
Two grand on a full tune up? Sounds like you got robbed my friend, and from a bad mechanic too.
Well first things first:
Scan for codes
Check your wires
Check fuel pressure
Check that ICM is getting signal to fire
Check opti
Scan for codes
Check your wires
Check fuel pressure
Check opti
Alex Barnes
Jan 24, 2015 10:21 PM
