Engine Harness suggestions
Im swaping a 5.3 LS into my 97 Z28, and the cheapest engine harness ive found is about $750. Its the t56 trans and the engine is driveby wire. I dont even know if that specific harness will plug into my body harness. Any suggestions on website or other companies that might make a cheaper harness? This is a budget build, but im trying to do everything i can right. i went through current performance wiring.
Re: Engine Harness suggestions
Have you checked sources like EFI Connection and Torqhead?
Shoebox has the body connector pinouts for each LT1 year.
http://shbox.com/1/harness_connector_faces.htm
wicked_95z
Dec 13, 2006 07:05 PM
