Engine Harness suggestions
Im swaping a 5.3 LS into my 97 Z28, and the cheapest engine harness ive found is about $750. Its the t56 trans and the engine is driveby wire. I dont even know if that specific harness will plug into my body harness. Any suggestions on website or other companies that might make a cheaper harness? This is a budget build, but im trying to do everything i can right. i went through current performance wiring.
Re: Engine Harness suggestions
Have you checked sources like EFI Connection and Torqhead? Shoebox has the body connector pinouts for each LT1 year. http://shbox.com/1/harness_connector_faces.htm |
I checked EFI connections, it’s actually more expensive, and torqhead only does LT stuff I have a gen III LS I’m putting in. |
