Engine Harness suggestions
Old Feb 26, 2019 | 03:17 PM
ballc123's Avatar
Im swaping a 5.3 LS into my 97 Z28, and the cheapest engine harness ive found is about $750. Its the t56 trans and the engine is driveby wire. I dont even know if that specific harness will plug into my body harness. Any suggestions on website or other companies that might make a cheaper harness? This is a budget build, but im trying to do everything i can right. i went through current performance wiring.
Old Feb 26, 2019 | 06:54 PM
Re: Engine Harness suggestions
Have you checked sources like EFI Connection and Torqhead?
Shoebox has the body connector pinouts for each LT1 year.
http://shbox.com/1/harness_connector_faces.htm
Old Feb 26, 2019 | 09:20 PM
ballc123's Avatar
I checked EFI connections, it’s actually more expensive, and torqhead only does LT stuff I have a gen III LS I’m putting in.
Greg88
Mar 17, 2019 02:33 AM
aknight_sa
Oct 16, 2011 11:02 AM
1970z28
Parts Wanted
Jan 2, 2009 04:59 PM
wicked_95z
Dec 13, 2006 07:05 PM
