Electric Fans Problem!
Old Dec 25, 2007 | 04:19 PM
DustinMcGowan's Avatar
My car stays very very cool. The temp might rise to 160 if im lucky. When I start my car the fans come on in about a min. and they stay on. Iteven happens when it is very very cold outside. When it get to about 160 I am able to get a little heat but not much. Can anyone tell me what is going on? It just keeps getting colder and I need some heat. lol Thanks
Old Dec 25, 2007 | 04:39 PM
Pyrodawg's Avatar
bad coolant sensor in the front of the block? i have the same problem but its not my sensor... i have a new sensor and it did it with the old one too... the pigtail however could be the culprit
when ive hooked it up to datamaster the temp will read 160* then 270* then 160 then 270 every other second so my cpu thinks the temp is going that high and keeps kicking the fans on...
check the pigtail/sensor/and wiring itself
Old Dec 25, 2007 | 04:56 PM
Check engine light on? Fans will run with most trouble codes.
Old Dec 25, 2007 | 07:14 PM
which side in the front is the coolant sensor on?
Old Dec 25, 2007 | 10:43 PM
Neither. It is on the water pump.
Old Dec 25, 2007 | 10:56 PM
thanks
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
97z28k&N
Jan 9, 2015 04:58 AM
Jul 4, 2005 05:00 PM
slothgrant
Aug 22, 2002 03:01 PM
