egr/air
Old Jul 16, 2006 | 01:52 AM
Daniel6718's Avatar
egr/air
i know for a fact i dont need my air pump but do i need my egr valve ect to pass emissions on a 94? as long as it doesnt throw a light correct? that means all i need to do is have tha egr connector plugged in??
and will not having an aip pump burn up the cat or just not make it work as well when cold? (since it jsut warms the caT)
thanks
Old Jul 16, 2006 | 12:04 PM
Re: egr/air
Removing the AIR pump will not damage the cat, unless for some reason your engine was running extremely rich in cold start mode. You can unplug the pump, and as long as the fuse in the circuit is still good, no code on OBD-I.
EGR is generally required to meet emissions, if they check oxides of nitrogen (NOx) in the tailpipe test. Might get by on NOx without it, might not. You may get a code for the lack of EGR flow.... seems like the diagnostic in OBD-I is not real sensitive, and maybe 75-80% of the OBD-I EGR deletes do not set a code for low flow. You have to leave the EGR solenoid connected, or put a resistor in the harness connector, or you would get a code for that, though.
All of the codes can be "programmed out" of the PCM, if necessary.
Old Jul 16, 2006 | 02:58 PM
Daniel6718's Avatar
Re: egr/air
just who i was hoping to answer..thanks
i removed the air and egr on my 94 and it did not throw codes when i installed headers...but i never tried to pass emissions...so what your sayin is that i probably wont throw a code...probably will still pass...but theres a slight chance it all will go wrong?
Old Jul 17, 2006 | 01:44 PM
Daniel6718's Avatar
Re: egr/air
bump...
Old Jul 17, 2006 | 01:48 PM
Re: egr/air
Sure.... it is possible to get DTC 32 in OBD-I. It just doesn't happen very often. And it is possible to pass a rolling emissions tailpipe test without EGR, it just makes it a little harder to pass. But its not a guaranteed failure with regard to NOx content.
Old Jul 19, 2006 | 11:43 AM
3DFORMULA's Avatar
Re: egr/air
Injuneer,
I just removed my air pump, on my '94 Formula, during opti inspection/replacement. No emission inspection here and dont want it back on. Have not removed everything yet, but will. Did you say that something has to be plugged in the wiring harness that was removed from the pump itself?
Thanks, Darrell
Old Jul 19, 2006 | 11:58 AM
Re: egr/air
Originally Posted by 3DFORMULA
Injuneer,
......... Did you say that something has to be plugged in the wiring harness that was removed from the pump itself?
Thanks, Darrell
No. You unplug the harness connector and let it hang.... nothing to plug into it. But to avoid a code you have to have a good existing fuse in the AIR power circuit. If your AIR pump was working before you removed it, the fuse is probably still good, and you won't have to do anything. Its important, because a lot of people delete the AIR pump when it siezes up and blows the fuse, and they have to know that the fuse must be good.
Old Jul 19, 2006 | 01:27 PM
Daniel6718's Avatar
Re: egr/air
^^ yep yep^^ btw injuneer you get my message? about the oil pan..whenever your free
Old Jul 19, 2006 | 06:23 PM
3DFORMULA's Avatar
Re: egr/air
I got ya, thanks, Darrell
ssclone
Exhaust System
Oct 21, 2010 07:18 AM
camarostripe96
Apr 1, 2008 05:17 AM
TransAm396
May 20, 2005 01:23 PM
350 HRSS
Mar 3, 2004 09:40 AM
zoomjrl
Nov 25, 2003 12:34 AM
