egr/air delete
Old Mar 31, 2008 | 11:18 PM
camarostripe96's Avatar
From: Academy,tx (Home to Temple/Academy Drag Strip)
egr/air delete
does anyone have pics of egr/air delete on a LT1 ... i am getting longtube with ory and wanna delete my egr/air what do i need to do to delete it? do i need to buy block off plate (and do they come with gaskets) ? do i need to take the intake off to block ? how would i do all this
Old Mar 31, 2008 | 11:23 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Search is your friend.
Old Mar 31, 2008 | 11:41 PM
jclark311's Avatar
You just need EGR block off plates, i bought mine from UMI Performance for around 20.00, i made my own gaskets, with gasket material from Pep Boys, check Shoeboxes website, it shows you what the EGR looks like, and no you dont need to remove the intake, just the EGR, and Air Pump.
www.shoebox.com
Old Apr 1, 2008 | 01:22 AM
Kaj's Avatar
Kaj
haha...hallmark isn't going to help out much lol
the link you need is shbox.com
lol
Old Apr 1, 2008 | 05:17 AM
Assuming the "96" in your screen name indicates the year of your car, you will get an SES light and codes for the missing EGR and AIR systems. The codes will need to be 'programmed out' of the PCM.
You will need a couple small vacuum caps for the AIR and EGR vacuum connections at the intake manifold. The exact details of the AIR vacuum system will depend on whether your car had the AIR recall done on it. You will need a 3/4" vacuum cap to plug the hole on your air intake, where the AIR connection for the air supply to the pump is removed.
stylin99
Feb 3, 2016 02:24 PM
tnmotown
Aug 10, 2015 11:52 PM
guest74777
Mar 25, 2015 10:30 AM
alex5366
Mar 8, 2015 11:32 AM
NVMYTA
Nov 23, 2002 06:04 PM
