dyno numbers are in and was hoping for more!!!!
Old Jun 24, 2003 | 08:34 AM
  #31
ONELOUDKAR's Avatar
what will happen if it wasn't installed straight up?
Old Jun 24, 2003 | 08:47 AM
  #32
Perry93TransAm's Avatar
If it was installed retarded it would move the power band around as would advancing the cam. ie advancing gives you more mid lower with a grind and retarding moves it up a bit. (or is it vice versa...lol, been so long since Ive done it). But that is kinda low for the peak, You know when I look at my dyno sheet it only was putting out a little over 300 hp from 5 to 5500 and the peak as said was a few hundred past 6000. since your A/F ratio is good the valvetrain is a possibility. I know when I was younger I had a 79 T/A and it had some weak springs and it would just like hit a wall around 4500 rpm. I just marked it up to something else until I had the heads redone because of a blown head gasket so I put in new springs and it would then go on up to 5000!
Old Jun 24, 2003 | 08:53 AM
  #33
ONELOUDKAR's Avatar
but when i had my bent valve replaced, he did a pressure test on every spring and he said they were all in good shape. He also cleaned everything up on the heads and did the whole 9 years.
i am just wondering if my tranny came into play here.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
ANDYZ28
Dec 29, 2014 09:13 PM
YellowT/A
Aug 7, 2002 12:30 PM
Joe Brodman
Jul 24, 2002 05:24 AM
