dyno numbers
Old Aug 30, 2010 | 04:43 PM
38394Z28's Avatar
dyno numbers
383, GM847 Cam, Eagle Crank, Eagle Rods, SRP Forged Pistons, 1.6 Roller Rockers, Comp Srings, 42lb Injectors, LPE CAI, Full Exhaust, and a PCMforless tune
made 342wheel and 354 torque on a Superflow.
We were initially going to tune it today, but the PCMforless tune was spot on I was really happy with those numbers for stock heads, intake and throttle body so thats why I thought I would post up the numbers.
ill post the actual sheets when I get to a scanner.
Old Aug 30, 2010 | 05:50 PM
Since you are quoting rear wheel HP, you need to include info on the type of tranny to make the numbers meaningful.
Old Aug 30, 2010 | 06:14 PM
38394Z28's Avatar
A4...
Old Aug 30, 2010 | 06:24 PM
38394Z28's Avatar
Ill just delete this thread. sorry I bothered
Old Aug 30, 2010 | 07:48 PM
94zrag's Avatar
He wasn't trying to put you down, just giving some helpful info. What tranny your car has makes a big difference in the RWHP numbers.
Old Aug 30, 2010 | 07:50 PM
94zrag's Avatar
And btw, that seems like some good power through an auto. I'd be happy with it.
Old Aug 30, 2010 | 07:55 PM
brucer's Avatar
what gears and converter you running?
Old Aug 30, 2010 | 08:30 PM
Jasonz28camaro's Avatar
you cant have that big of injectors stock tb and stock heads and expect big #'s
Old Aug 30, 2010 | 10:40 PM
henryz28's Avatar
You are really in need of a set of Heads. Was this on a mustang dyno?
Old Aug 30, 2010 | 11:12 PM
You completely misunderstood the purpose of my question. It was not an attempt to minimize or belittle your accomplishment. The type of trans affects the rwHP, and allows a more precise evaluation of the flywheel HP. I thought that was important, as it makes what you have done more meaningful. The results are impressive.
My sincere apologies fo offending you..... It was not my intent.
Old Aug 31, 2010 | 01:15 AM
RamAir95TA's Avatar
Not to put you down, but why on earth would you go through all the trouble to build a 383 only to put in a dinosaur cam on stock heads? I'm not really impressed by those numbers, but at least you are.
JMHO, of course.
HarleyZ28
Oct 5, 2015 06:23 AM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
BLK1997Z28
May 7, 2015 03:01 PM
racecarz28
Mar 30, 2015 09:55 PM
Joe Brodman
Jul 24, 2002 05:24 AM
