want to get otvc wires
Old Mar 12, 2008 | 09:42 AM
djlunchbox's Avatar
i am having ignition problems, and i have been reading on a few fixes here. i'd like to get new wires and plugs for starters. i have taylors on there now, but they are not routed correctly. i'd like to get them over the valve covers and run them down due to my headers. what kits do you reccomend? will i have to get a special set of "make your own" wires so i can weave them in thru the tight spaces on the lt1? any help would be great, the wire sets i see always seem too short, and the lt1 "premade" kit from taylor is too short (i tried before), unless i'm missing something. what do you all use?
Old Mar 12, 2008 | 10:55 AM
2000GTP's Avatar
Thunder Racing sells a kit that includes the wire set, the crimper tool, and the over the valve cover wire loom set. You could also purchase those items individually on there as well. You will have to cut and crimp your own wires though. There was a company awhile back, Elitesparkplugwires, that sold the premade sets but is not longer in business. Those are the wires I currently have with my OTVC setup but will be cutting my own with the Taylor kit sometime in the near future.
Old Mar 12, 2008 | 11:05 AM
northdakota93z28's Avatar
i just finished my otvc wires got them from thunder racing it took one month for them to come, they were on back order. but they are cool.
Old Mar 12, 2008 | 12:46 PM
caldercay's Avatar
I ordered the individual items from Summit, in stock:
* MFY-5035613 WIRE LOOMS
* MSD-32129 WIRE SET CHEV LT1
Those are Made4You OTVC looms. The MSD set are booted on one
end and you will have to boot the other after cutting to length. The
cutter is included with the wires, along with cylinder ring-markers.
Old Mar 12, 2008 | 06:57 PM
djlunchbox's Avatar
thanks for the replies guys! any pics ?
i will check out thunder racing now for that kit.
calder, are the msd wires long enough?
Old Mar 12, 2008 | 07:15 PM
caldercay's Avatar
Yes, the MSD's are long enough - they provide "too much" length,
allowing you to cut to size (obviously, in case of re-routing wires).
Old Mar 12, 2008 | 08:00 PM
dangalla's Avatar
i would not reccomend the kit from TR, i have it, and it took over a month to come in.
i would reccomend you get the holders from summit and get some wires other than the taylors, they suck
Old Mar 12, 2008 | 09:12 PM
Josh'95Z28conv's Avatar
Ive had my kit from thunder for a couple years. Arrived in one day as does everything Ive ordered from them
OTVC wires are a must with LT1s.
Old Mar 12, 2008 | 09:29 PM
caldercay's Avatar
Originally Posted by Z28Roxy
Screw you mine work fine
Anyway, here are a couple pics. Girly purple which you probably don't want
Wow - girly purple AND those big fuzzy aerobics socks to boot [sic]
Old Mar 12, 2008 | 09:42 PM
Ricardo's Avatar
You could also use the MOROSO 73210 set.
In stock for inmediate delivery. Great price.
Old Mar 12, 2008 | 09:45 PM
dangalla's Avatar
mine look better
Old Mar 12, 2008 | 09:59 PM
Ricardo's Avatar
How do these look?
Old Mar 13, 2008 | 01:46 PM
Craddock's Avatar
Where did you all get the hardware to bolt the wires to the valve covers? I'd love to do mine like Roxy's, but in red.
Old Mar 13, 2008 | 02:16 PM
guest74777's Avatar
Guest
i have the thunder racing kit, worked for me. I like my taylor wires i have never had a single problem with them
Old Mar 13, 2008 | 02:27 PM
JasonK94Z's Avatar
Thanks for posting that! thats a great price on some otvc wires for the LT1.
