dyno numbers!!
Old Nov 4, 2003 | 03:10 PM
  #16
Originally posted by lt4 fd
.....and it was 100 degrees when I dynoed so if it was 50 how much of a diff would that be? OH and my nittos were at mid 20's psi like 24 or so on the dyno is that enough or should I inflate them to normal street tire pressure?
Your dyno sheet should show "SAE corrected" HP. That would take into account the temperature, humidity, barometer, etc. A 50degF temperature drop is worth almost 10% on HP.
Old Nov 4, 2003 | 11:05 PM
  #17
lt4 fd's Avatar
... so if I dyno my car in the fall or winter ill have 330rwhp, sounds like kind of a lot for an lt1, not doubting you just wondering why you dont hear of those kinds of numbers more often, do people generally not dyno when its cooler out??
Old Nov 4, 2003 | 11:22 PM
  #18
Seal's Avatar
Originally posted by Dmx4ever3
i disagree with those numbers sorry but i had all the boltons my car got it dyno with out my engine work and got 275 rwhp so i find that hard to belive with me have more work done then u
i dynoed just that with a cutout and intake...
u better get rid of that sick car
Old Nov 6, 2003 | 01:59 PM
  #19
lt4 fd's Avatar
about what injuneer said, im not totally sure what SAE corrected means, can anyone clarify?
Old Nov 7, 2003 | 10:51 AM
  #20
drewstealth's Avatar
I'm not 100% sure on the meaning of it but i know that it takes into account the temp outside, dew point, barometric pressure, and the altitude you are at. That is the SAE correction. They use this so that you can compare 1/4mile #'s and dyno #'s and stuff like that. Because the same car isn't gonna dyno the same at 3,000 feet as they would at sea level. Also if its 100* you would dyno lower then you would at 50*. So it is just used to find an equal point so you can compare #'s and times farely. I hope that helped. Maybe somebody could word it better then me.
Old Nov 7, 2003 | 01:01 PM
  #21
madhatter's Avatar
Don't be a hater
I dynoed 268/318 stock and 274/319 wiht cutout.
HarleyZ28
Oct 5, 2015 06:23 AM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
BLK1997Z28
May 7, 2015 03:01 PM
racecarz28
Mar 30, 2015 09:55 PM
Joe Brodman
Jul 24, 2002 05:24 AM
