DTC MAF Question
DTC MAF Question
Ok, I'm still working on this but thinking maybe a guru will be able to give me a quick answer.
'95 Z28 OBD1 car
I'm getting a DTC 23 error code or as Datamaster puts it MALF 23: MAT Low.
I'll be checking wiring etc. but wondered if anyone's run across this.
For the record I've searched and not found this specific code. Also this is on a car with air pump and EGR removed.
Descreened the MAF years ago but problem is new.
'ppreciate the help offered
'95 Z28 OBD1 car
They call MAT as Manifold Absolute [or Air] Temperature. It translates to IAT as we know it.
DTC 23 = Intake Air Temperature (IAT) sensor circuit (signal voltage high, low temperature indicated)
IgorT.455/406
Mar 12, 2015 03:39 AM
formula218
Dec 2, 2014 04:27 PM
Chrisdude
Jul 24, 2002 02:25 PM
